lifted 96 xj $3500 obo
dhreeves
Aurora
1996 cherokee sport, power windows, power locks, cruise, a/c, 4.0, auto, sony cd with mp3 and aux input, tinted windows. This is a good daily driver as well is it is built for 4 wheeling.
Mods include:
- 31x10.5 bfg at with apprx. 60% left
- 3.5 inch rubicon express super ride lift
- slip yoke eliminator
- Tom Woods double cardon rear driveshaft
- ford 8.8 rear axle with limited slip and disk brakes
- 4.10 gears
- JKS quicker disconnects
- JKS heavy duty tie rod
- rubicon express adjustable trackbar
- extended stainless steel brake lines
- slotted and cross drilled rotors on front
- ford mustang 5.0 injectors
- 99+ intake manifold
- header
- custom exhaust
- live wire plug wires
- screamin demon coil
- K&N cold air intake
- newer high performance head
Recently replaced parts include radiator, heater control valve, all tie rod ends, power steering pump and res., spark plugs, cap&rotor, front and rear brake pads. It does have 243,000 miles but I just did a complete compression test and all cylinders were between 120-130 psi which is well within specs. come check it out, it looks and runs great and is built for 4 wheeling.
Call Don at 303-663-8793. Asking $3500 obo
