Lift questions
EmJay89
Greencastle, PA
So I have a 97 xj with a 3.5" full traction lift and i wanna add a budget boost type lift (2" coil spring spacers and 2" longer shackles or blocks) Just wondering if there is anything else i need to do along with that, maybe adjustable control arms??
control arms, adjustable are prefered.
adjustable trac bar if you dont already have one.
longer sway bar links or disconects if you dont already have them.
once everything is in, double check your driveline angles to see if you need to drop your pitman or trac bar. my guess would be that you wouldnt though.
