dandecicco
- Lemoore, CA Dammit to Hell
Finally finished bumping up another 2 inches. After having to cut through my floor boards to get to the cross member bolts to lower the T-case (person before me had a new tranny put in and they welded the botls in), I didn't run into any other problems. I did a driveway alignment and track bar was already adjusted enough prior to the lift to still fit. After the test dirve, no vibes or death wobble. I still can't believe I adjusted everything perfectly before driving it the first time. Well, guess I need some brake lines and flex the back to make sure the drive line doesn't puke itself out.
Now what do I do with my evenings?
Pick and Pull has those doors for cheap . . . . . .
