jayuu
- madison, wisconsin
ive searched but none of it worked.
i have some led taillights and i cant get them to work right. my problem is that both sides flash when i use the turn signal with parking lights on or off, and when the brakes are on there is no flashing just brakes.
i have the grounds all grounded)blacks and white). i have the parking light wires (blue with red stripe) hooked to the wire its supposed to (black). and the turn and brake wires (white with stripe and tan) to their wire (red). these are the instrutions on the taillights wiring for hooking them up.
i tried switching the hazard and trun signal flashers but didnt work.
are these wired wrong? or is the hazard signal not heavy duty enough/ need an electronic one? thanks for any help as this is asked semi frequently it seems.
