LED Tail Light Flasher Frustrations
Summertime Boss
Virginia
Installed a set of JCR Offroad HD tail light housings with the LED lighting kit from their website onto my 2000 XJ. The write up for the LED lighting kit notes that you need to install an EP27 flasher to get rid of the fast blink rate associated with the reduced load from the LEDs. Got them all wired up and installed and the blink rate slowed with the EP27, but it also caused another issue. The tail lights now blink along with the turn signals. Also, the third brake lights are flashing with the turn signals.
I tried putting the OEM flasher back in, but it just buzzes and the lights don't flash at all. The lights are wired correctly. Also, I removed the towing lights altogether, so that isn't an issue.
Do I need a different flasher? Do I need to add resistors to the flashers? I found a few other mentions of this problem on various forums, but none of the postings were more recent than 2006 and none seemed to have a solution. Help please.
Could be a wiring issue if the tail lights and third brake light blink along with the turn signals. I would look for a bad ground.
When wired right LED taillights work fine with an electronic flasher.
Old school method is to add resistors to each LED to duplicate the original resistance, so the mechanical flasher works correctly.
Which leds did you order? Oval red for tail light and brake, round yellow for turn signal and round red for side marker and a seperate back up light? If so they should be a direct swap and flash corectly with the new flasher. If you are using the red oval for tail light, brake light and turn signal you will need a trailer tail light converter also.
It is likely a small amount of stray voltage in your wiring. I have just one led in the center of each of my lights light up whenever voltage is applied anywhere in my system. I could probably find a fix for it but it doesn't bug me much.
Maybe a dumb question, but while I have switched out my tail/brake lights with LED's, haven't tackled the turn signals yet (precisely because I didn't want to deal with this issue) so I'm not familiar with that aspect of the wiring . . . but dumb question or not . . . is the electricity for the tail somehow wired through the flasher unit? I wouldn't imagine that it would be, but you never know. Anyway, it would seem like an easy explanation as to why everything apparently blinks when he hits the turn signal. Everything else seems odd. Though, ground issues can do some strange stuff I guess.
That's a classical example of a ground problem, check the grounds at the tail lights. Only the turn signals go through the flasher, not the brakes or running lights.
