I was thinking if you string
e.g. four lights or LED light bars together at 10 amps each in a series from a 15 foot pwr cable you would need 15 feet of 4 AWG wire.
If you ran them in parallel you would need 4 x 15 = 60 feet of # 10 AWG wire or if you connected 2 each, 2 x 15 = 30 feet of # 6 AWG wire.
(calculations base on a 3 percent voltage / pwr drop ... 2 percent would require a larger gauge wire)
There are variouls methods to feed power and switch the lights.
Switches runs from around 10 to 20+ dollars each, whereas as relay can be purchased (12 pack) from around a buck to two buck each.
I drew a simple diagram that should work to string four relays together from a single switch. Using DesertRunner's "Normally off with ground trigger" diagram.
(Instead of running wire you could either jumper, use a diode or resister to 85)
Each device can fused for added protection or may come with their own fuses in their wiring harness.
What do you think about this method?, i.e. using a single toggle switch to ground.
The trigger wire (gnd) can be small gauge so you could use a 4 wire cable to control all four lights from one multi function switch.
