Leaking fluid at rear axle on D35
bleech1
Albany, NY
I thought my recently replaced wheel cylinder hatched due to the presence of fluid coming out of my drum. Pulled the wheel today and I find that its coming from the axle.
This means the seal, right? I haven't really looked into it yet, but can someone steer me in the right direction?
What year axle? C-clip or Non-C-clip ?
Non C-clip -you will have to replace the axle bearing to replace the seal-Press off-press on.
C-clip---Pull cover,drain fluid,remove cross shaft,remove C-clip pull axle.Seal is at end of axle housing,R&R.Check axle shaft for grouve(SP) or worn bearing area,replace or reinstall axle
Wayne
