Leaf spring bushings
Jbh97009
Damascus, Oregon
Need to replace my leaf spring bushings, just wondering if anyone has any advice/suggestions on what to use?
If it matters, they are RC leafs, which from all the research I've done use the same size bushings as stock xj leafs....
I've heard nothing but bad things about Rough Country's bushing quality. Not surprising to hear.
I'm not familiar if RC uses a standard bushing OD", but I've had great luck with BDS' poly bushings. #BDS074008, Gresham 4WD is a local dealer. I can measure mine if needed.
They are confirmed same size as factory bushings. I knew they were crap, I should have just replaced them before I even installed the leafs....
Just wanted to make sure poly were ok because I don't have any long term experience with them
