LCA Q's
Haulgas
Goodyear Az
I'm going to fab up some LCA for my 92xj. Do any of you know what size tubing or pipe has the correct I.D. for OEM bushing ? I would like to use OME bushings at first then I will move on to JJ after Get them figured out.
Thanks Brian
http://www.rocklogic4x4.com/
At least use a .25 wall DOM, 2 to 2.5" OD. Pipe is not recomended.
2 5/8"x.188"wall,then you have to machine about .030" out of one end!
Haulgas said:
Thanks guy's. RCP where did you get the DOM?
I got it from Modesto Steel(209)526-5306.It was 40$ bucks for 2 feet(w/ cut/ship charges)!
Thanks Brian
I have a CAD print I can email you if you like.
