bcmaxx
- The West Kootenays,B.C. Canada
Is there any good ways to removes or cover up the while raised lettering on my new mtrs? They have an inboard side and an outboard side and can't be reversed. thanks
Maybe an even sillier question, but do you have to order left sides and right sides? Seems the white lettering would be on the outside on one side and the inside on the other if you don't. If you do, just have them mount them so all the white lettering is inboard.
They are just marked inboard and outboard , I cant see them working right If I put the black out :![]()
Yeah you'd think they'd be directions but nope. No other markings for orientation except the in and outthose are odd looking tires for sure. I can see that they're asymmetrical, but the treads also look as if they're directional, like tractor tires, so that the fronts don't match on direction. Are there really no directional arrows on these? I'd have guessed that you'd need two mirrored pairs to make a proper set.
Look again, I think you were right the first time. If the tread bars aren't as far apart as those on a tractor, it probably doesn't matter which way they go, but it still looks odd. I looked up some reviews and such, and none of them make mention of directionality, so I guess that's the way it's supposed to be.I wonder if the tires on the right side where the V is backward perform less well in mud.
Edit: wait... the outside tread blocks go the same way on both sides. It's not really a V.
On the original question, could you grind the white off the letters with an abrasive disk? Kind of drastic, but it ought to take the white off pretty quickly if it's just painted on.
Rubb them against a curb for abouts 25 feet.
