- Henderson, NV
I just did a blend door replacement on my neighbors 2000 WJ and everything is back together and working like it should. EXCEPT, The key in ignition warning chime wont stop when the driver door is open, even if the key isn't in the ignition.:gonnablow All the lights are off and the ignition is in the off position. when you shut the door it stops or if you start the jeep it stops. His key, like so many other 99-00 jeep keys, can be pulled out of the ignition at anytime. I am wondering if this could be the culprit, and if so How do I fix it. :thumbup:
P.S. dont hate on the WJ, I personally drive a 99 XJ:wave1:
