This is more of an individual benefit thing,as you stated "me".Others may need more than stock cause of the way they may drive or use thier clutch when wheelin.Some may not need anything more than a stock clutch.I can say that if a stock clutch lasts you a long time then a Kevlar one will maybe last you forever.it really all depends on what you have on your particular set up,gears ,tires,type of terrain and how you drive,if your a heavy throttle person then a lot more stuff will break.if you can relate to some people that break stuff a lot and what they break to other people that do the same as the first person with the same running gear and do not a have single breakage,then you can see a benefit,or at least I can.I got this one as a free product to partisipate on some real world R & D ,i am trying to see the benifit as you are too.hell everytime I go by the place and stop in the manager keeps askin me are you ready to abuse the hell out if it yet? It is almost burnished in.in your reply about the stock one not slipping,it wont, it is not of the same material as the one i have,and the K one needs to be burnished in for it to perform as designed and will have slippage until the fibers have settled.I have 560 miles on it now and it only slips when I hammer on the throttle in 3rd gear-my torque load situtaion will be different from others-it slips for 50-100 rpms for a second and then grabs.Almost fully broken in.I posted this here only because I am a tester for this unit and all the feedback I recieve - good or bad -is what I need to relay to ZOOM.I do agree with you on thinking about it as a possible stupid alternative to gearing or what ever was on your mind ,but then again would you drive on 35's with 3.07 gears in an automatic trans? Sure it wont slip ,but sumtin will break for sure or overheat.33's and 4.10 gears by the way-no suk gearing here.
This was also an opertunity to post some more results as milage progresses
