From the standpoint of someone who devotes to much time to oil (me), I wouldn't run it because it contains too much sodium in its 'add pack' It would scew up my results unless I had a virgin sample of the same batch. I think Exxon Superflo would give you better results if you went with the low cost dino.
As long as the add pack in any oil is healthy, more for our cams, you can run it 3k no problem. After that, the anatomy of the oil is tested. Synthetics-stading up to a lot more abuse.
