Gerr
- River Drive Norco Ca 92860
damn man I wish I had gotten half that much done on my junk this weekend. nice progress
ROBERTK said:Hoping to get it done by April 28th for the Tinbenders jambo at the Hammers, but doubtful. Theres about 6 days in just front inner axle build and delivery time.
xDUMPTRUCKx said:so are you now a owner of the hammers?![]()
David Taylor said:I wonder what a full hydro setup would look like on that ? Have you thought about going to it in the future ?
ROBERTK said:Full, not so much. Maybe an assist. But I am Broke now. Have just enough saved for the line lock, and inner axles. :confused1
xDUMPTRUCKx said:37s and stock power steering?
ill be sure to grab the ps pump and box off the parts jeep at russ'![]()
dzraces said:how much was the line lock? I have a manual one I plan on using for a parking brake the electric would be sweet for my YJ though
both my heeps run dual deep cycles the current draw is no biggie for me but one group I run with requires a manual parking brake that will hold you in drive, so that is the only reason I snagged the one I have. It was only $5.00 at the pamona car swapmeet so I cant complainROBERTK said:39.99 from summitracing.com or thier ebay auctions. I was going to go manual so that I could set it over night and not have current draw. but I never park over long periods of time where I would need it for that. Just for on the trail when I get out for something or cutting brake now if needed. Yeah right. lol
dzraces said:both my heeps run dual deep cycles the current draw is no biggie for me but one group I run with requires a manual parking brake that will hold you in drive, so that is the only reason I snagged the one I have. It was only $5.00 at the pamona car swapmeet so I cant complain
juryrigjalopy said:They actually draw quite a bit of power considering what it is. I had dual batteries in my YJ and it drained them perty quick. They really should not be trusted to hold for a long time because they can leak over time.
ROBERTK said:well just dont follow me.. Cause that means IF I dont break then I will brake, and not be able to go. lol
In any case I have used the summit one on a very high power muscle car during hot lapping and know that the brakes (and prolly fluid) were getting hot after the 4th run and never had an issue during the burn out of not releasing when turned off.
So I hope I have the same luck if that is an issue.
