Just some of the Progress
tkjeeper
Some of the progress of a part time wheeler.
The Sanden OBA setup:
Oiler and One Way Valve to 3/8" copper
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts014.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts014.jpg" border="0" alt="Photobucket"></a>
K&N intake filter
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts015.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts015.jpg" border="0" alt="Photobucket"></a>
Over to pressure switch and inline oil and water separator/filter. Zip ties are temporary.
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts016.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts016.jpg" border="0" alt="Photobucket"></a>
Back to manifold and first rear tank, manifold has pressure relief valve, guage and outlets to other tank.
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts012.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts012.jpg" border="0" alt="Photobucket"></a>
Over to second tank with regulator.
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts013.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts013.jpg" border="0" alt="Photobucket"></a>
Over to the only outlet for now, I have a 50' hose so I'm set.
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts.jpg" border="0" alt="Photobucket"></a>
Thought I might as well show my rear full depth drawers.
Closed
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts010.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts010.jpg" border="0" alt="Photobucket"></a>
And open
<a href="http://s157.photobucket.com/albums/t72/tkjeeper/?action=view&current=parts011.jpg" target="_blank"><img src="http://i157.photobucket.com/albums/t72/tkjeeper/parts011.jpg" border="0" alt="Photobucket"></a>
Dang, you got air!!!!
I have been collecting parts for sometime to do this. Everytime I see someone else do it, or I take the rig out on the trails I tell myself its next on my list... its next on my list.
Lookin good man.
very nice setup sir :)
I ride with the tanks empty usually, takes approx 20-30 secs to fill both to shut off level, 145 psi. When I use the attachment to blow dirt off or fill beach toys with the compressor running I cant get it to fall below 120 psi! Amazing since my shop compressor empties out in about 20 seconds, quite impressive! Thanks guys.
stxcherokee said:
what size copper tubing did you use.. along w/ what size air lines and fitiings
From compressor, 3/4-3/8 reducer to oiler, 3/4-1/2 reducer to one way valve, compression fitting to 3/8 flexible copper line over to oil separator to 3/8 air hose line to pressure switch through firewall under sill trim to back tanks to manifold over to second tank to outlet in gas fill up. Let me know if you need more info.
