GrimmJeeper
- Gardena, CA
me too! im sure we arent the only onesLong shot i know but i'm looking for a factory fiberglass header panel from a 97 and up..
Okay, here's a good one: Looking for a 4.3L Chevy engine and a 700 R4 transmission, probably early 90's. Don't ask why........it will be revealed at a later date! :wierd:
Please let me know if someone finds one laying around. :wave1:
Thanks
I need a set of stock MJ front coils. or XJ coils if they are the same... im not sure :dunno: also if anyone sees a set of 2 or 3 inch lift blocks on a mini truck at the JY i'll take em if they are easy enough for you to pull off.... or if someone has a set from an XJ laying around...... :cheers:
socal rocks!
Phuck Yes It Does!!!
Looking for aD44 front and rear axle out of a scout. Found a pair on CL but the guy wants a grand for them.
Just got back from Santa Fe Springs Ecology on Imperial;
2 Comanches both 2 wd. One long bed the other short, one has the tailgate.
Several pre 1997 Cherokees, one with full factory skids, one with factory front tow hooks, another with an after market sun roof.
One RENIX XJ has new front brakes and rotors, must not have done it right, the front is crunched.
V8 Grand Cherokee, the front springs give a bit of lift on our XJ's
I didn't see and Dana 44's.
Sorry, I won't go back. I need to fix the plumbing under the kitchen sink.
Mike
