CartsXJ
- Glenville, NY
a little hardinge chucker, or a clone?
Yes, our "little" lathe at work. We do have a smaller one but the precision sucks on it.
He uses tie rod ends that are offset. Not heims
nice, those are my favorite little lathes. I have a cnc version of that, with a little 8 position automatic toolchanger.Yes, our "little" lathe at work. We do have a smaller one but the precision sucks on it.
Whats the mounting width on that track bar mount? 1 5/8?
http://www.tntcustoms.com/trackbarsystemmjxjzj.aspx
TnT also makes two different axle side trackbar mounts. Only problem with most of these is it makes the TB very short. Even with the JKS bracket, my trackbar is pretty damn short.
^^^ do you have better pictures of your bracket and the contact that is being made?
If I remember right, it was something like ~1.699". So I am guessing designed for a 1 5/8" width joint with ~.040" worth of tightening up and room for variation.
takes 2 seconds with a lathe...I run 3/4 heims with the misalignments machined down to fit the bracket.
I'm resurrecting this old thread because I'm building a track using ruff n stuff
3/4" rod ends with 5/8" high misalignment spacers, I just realized my track bar bracket if built for a 1-5/8" wide rod ends, the width of the rod ends with spacers is 2".
Should I cut the spacers down to fit? Or can I get 3/4" x 5/8" rod ends that are 1-5/8" wide anywhere?
Thanks in advance!
Synergy makes some that are 1.6 wide for their 3/4 heim. Only a few bucks a piece. Also available on amazon from them as well.
