JKS Adj Lower Control Arms.
Hammered
Jeep Fiend Club
Never installed. However these were in a tool box inside a garage that burnt to the ground. I cleaned em up & Painted em (shitty job / cold) powder coating is in pretty good shape, Greased em. They move flawlessly. Ready to go. (you will need to order new bushings for one end see image) These things are beefy.
I'm asking $150 shipped OBO... I need money asap.
FROM JKS site
Take CONTROL of your Jeep® suspension with new upper and lower Control Arms from JKS. The adjustable design allows the user to control caster and pinion angle, as well as position the axle housing for proper tire clearance. Furthermore, each end of the control arm can rotate independently to accommodate extreme suspension travel off-road.
JKS Control Arms utilize greasable brass bearings for smooth, reliable operation and excellent longevity. Fine pitch adjustment threads ensure superior strength and unsurpassed tuning ability. With over 3" of adjustment, the working length of each JKS Control Arm can be increased, decreased or exactly the same as the OE suspension arm.
Constructed of heavy-gauge steel tubing and MIG welded for quality and consistency, our Control Arms are much stronger and resistant to impact than the original suspension arms. New OE rubber bushings are used to isolate road noise and vibrations without over-stressing the mounting brackets. Finally, a durable powdercoat finish and zinc plating provide excellent corrosion protection.
Location Suspension Qty Part # Price Lower, Front 0 - 6.0" Lift Pair PN 6100 $375.00
So Zero to Six.
whoo! deal of the day! hell i'm almost tempted to buy em for my DD, but i know that's badddd. not to mention i have way too much to buy for the big one anway. good deal, good luck with the sale
Would they be bad on a DD? I'm tempted for my stocker...
Do you wheel your stocker? I can tell you that if you do, the OEM LCAs are like tin foil.
I just gave up (after killing two sets of OEM LCAs in a year, one set ended up looking like WJ LCAs :scared:) and installed a set of these. So far, street manners seem identical to OEM, since they use rubber bushings, and they can be adjusted down to stock length.
Rob
