JK vs TJ 241OR??
Mainly that the JK doesn't have a speedo gear.
I own a TJ one too, but whether you call it a gear, drive, or sensor the JK doesn't have anything. Plus the JK uses a different input gear.
Yes it bolts right up.
But you won't have any kind of speedo signal at all.
IIRC there was a way to trigger it off of the tone ring on a Ford 8.8 third member if you have one? Maybe involved shaving every other tooth off?
I still have the stock HPD30 and 8.25.
hrmm
Also I was searching Ebay for a 241 and are the 241DHD and 241D geared the same? they come out of the dodge trucks
