jimgrms' WJ Build Thread
xj-grin
NAXJA Member #1096
I'll start it, and then someone will have to teach Jim how to use photobucket and post pics... :kissyou:
1. Varilock/Quadradrive Axle Swap:
dirty and gooky:
cleaned:
pretty and black:
you take it from here, Jim!:sunshine:
Got the discos 2 1/2 pucks adjastable track bar front tow hooks ,t/c skid , adjustable shocks , to be built sliders and tire carrier, guess i will have to get a camera and take some photos , if ya haven;t heard i got a 2002 grand cherokee 4.0 6 242 t/c less than 90 k on the clock, a real clean ride but it has no attitude yet gotta get me a camera and fluid for my new axels
WOOT!
Good luck with the build.
Finished the axels and the heep actually drives nice w/just a trace of wobble , Still needs to be aligned , The rear drive shaft is to long so right now i am in 4wd, will do that tomorrow ,also the new rear shocks are to short so that will have to be rectified ,
had to do a little triming on the front as there was some rubbing
i tried to send some photos but can't figure it out . all in all i am happy with it remains to be seen how it works on the trails
it turned out to be more just upgrading to better parts ,it is lifted with pucks (2 1/2 " with rancho 5000 adjustable shocks 17 in moab wheels and 255 75 17 bfg km2 mt that are siped . still to come are sliders and a swing out tire carrier ,if it works as good as my old xj did i'll be way stoked , thanks Kiefer :>{))))))))
looks great, Jim. Looks like you'll be trimming a bit as well!
Should work BETTER then your old XJ! And Jim, Don't worry about lunch! Ill have to teach ya how to post pics some time!
its that new goatee -- the chicks dig it.
your speedo, unlike in an XJ, will require one of those pricey piggyback computers or a flash to correct, as it comes off the tone ring for the ABS, not the t-case, so you can't just swap gears... bummer. I was hoping the 3.73 gear change might offset the tire size and get you close.
