mayub78
- El Paso Tx.
That was last November, I just came back from the SCORE 250, didn't do much pre-running, but are working very well, I'm very happy with them.
It gives you 1/2" of lift, I have a 4.5 lift with 4.5" rear leaf springs, but you wouldn't even notice it, because 1/2" is going to be lost on your leaf spring with there normal use!! fully recommended for use with Deavers!!
I've got a set of composite rear leafs for a Comanche. #175.
PM me your email address for photos.
ive been running rustys jeepspeed rear spring for 2 seasons now and they have been great i also run the liquid iron sliders and will never run shackles again we race the dirt riot and ecors on the right coast.well does anyone have any info on these Rustys 4in. jeepspped springs?
Okay I'm both answering the question above and bumping this thead because I have a shackle question and I hate starting new threads.
First, no you can't just mount your leaf pack under the axle. Even though we knew it wouldn't work, we tried it on a Ranger with Deavers (we had some time, don't ask). You end up lowering the truck about 8" and your shackle angle (basically the entire rear geometry) is way off.
Okay my question: What is the most ideal shackle set up for go-fast on an XJ? Assuming I have Deavers, how long of a shackle are JeepSpeeds running and how long if you don't have to conform to Jeepspeed rules?
My plan is to run the HD off-road engineering shackle re-location brackets. So the last piece of the puzzle is the shacke itself. I alreay have 1.5" extended shackles, but they seem short compared to most traditional truck shackes I have run in the desert.
My concern is drivetrain issues with too long of a shackle. I'd rather not R&D something that may be already known.
Am I worried about something for no reason? Am I going to get say 14" of travel with deavers and my shackles, and maybe 1" more if I make big changes? I don't split hairs over an inch of travel, I just valve my shocks a few extra times![]()
I don't want something that works grate unless I'm putting cheese on my pasta.
What about the IRO 5.5" pack? 7 leafs, Military wrapped, yada yada yada.
