nate
- Anchorage, Alaska
Shipping will be extra from the prices and will be whatever is costs to box it up and ship. Shipped from 99504, so guessimate what it weights and you can probably come close to what it will cost. I take paypal or money orders...
PM me, post, or call 907 830-2812, between 10AM-10PM AK time please. Leave msg if I don't answer. Prices are obo, but don't insult me either.
- Complete YJ steering setup, good shape, I think a boot is torn though. $10
- Complete ZJ/TJ/XJ/MJ steering setup with Rubicon Express tie rod. Draglink and TREs new this fall, RE TR a year or so old, good shape. $100 SALE PENDING
- Complete ZJ/TJ/XJ/MJ stock setup, joints are "ok", would be good for spares $20
- ZJ/TJ/XJ/MJ draglink, good shape. I think the boot is damaged though $20
- ZJ Tie Rod, bent, TREs on it are good for spares $10
- 2 or 3 loose TREs that are in ok shape. $10
- 2 ZJ/TJ/XJ/MJ front shocks, Bilstien, stock height. Seem to be ok, need new bushings though $10
- 2 ZJ/TJ/XJ/MJ Old Man Emu front shocks for 4.5" lift, about 2.5 years old, good shape. I think I painted them black at one point or another though. $80 SALE PENDING
- 2 ZJ/TJ/XJ/MJ Old Man Emu rear shocks for 4.5" lift, about 1.5 years on them. Still yellow $80 Both sets $140 SALE PENDING
- 2 ZJ/TJ/XJ/MJ front LCAs. free
- 2 knuckles off 85 XJ D30 $10
- 3 unit bearings for 85, 86/87 XJ (old style knuckles), 1 is almost brand new, other 2 unknown miles... good for spares. $80 for good one, $10 ea for unknowns.
- 2 calipers, rotors and pads for same rig $40
- 1 LP D30 housing from a 2000 TJ...good shape.. could use for brackets maybe? $30
- Rubicon Express Hack and Tap. Complete kit, I can even throw in a cut mainshaft if you want it $50
- Stock 4.0L exhaust manifold. Starting to crack, not too big, could weld it $10
- 2 Rubicon Express control arm drop brackets w/homemade braces $125... SALE PENDING
- 8 Rubicon Express Super Flex Control Arms, rears are adjustable, front aren't. Good shape, could maybe use new rubber bushings (like $7 ea) $350... SALE PENDING
- 2 Rubicon Express sway bar discos. They are worn and beat up. Still work $20
- 4 Rubicon Espress coil springs, 4.5" lift.. fronts are painted black. $165... SALE PENDING FOR FRONTS
- 1 ZJ power steering box. Works, but it's worn out. $20
- RE 1" T Case drop $10
- Impact Gun. Works good, maybe 75-100ft/lbs.. $15
- Ford 8.8 4.56 gears, 5000 miles on them, Genuine Gear, run a bit loud $20
- LP D30 4.56 gears, about 10,000 miles, good shape. $40
