xylonjay
- Minneapolis,MN
I leave work every day for lunch and drive about 10 minutes to home. I stay for about 20 minutes and leave. Here is my problem: When Im leaving to go back to work, my jeep will start and the check eng light comes on. Then when I put it into reverse to back up and let out clutch it sputters and dies out. I can usually get it to run fine after about 5-25 tries at starting it, and it seems to only do this after being driven, shutdown and then restarted. Ran a scanner on the ECM and the codes were "below recommended minimum voltage" issues with the TPS and MAP sensors. I replaced the MAP sensor, and TPS and still having the same problem. Any ideas on what else to try?
