jeep parts for sale : lift , tires, and more
blondejoncherokee
sacramento
josh and i bought a jeep(salvaged on here)
here is the stuff we dont need that we would much rather sell to the sierra chapter
32x11.5x15 maxxis big horns , real good tread
rear 3.5" 7 leaf pack, deaver, leaves without main leaves
shackles tnt boomerangs
front shocks, bilstein 5150s with res
29 spline 8.25, ruff stuff cover countersunk holes and drain plug, raised shock mounts, 4.56s, posi, stock shafts
beefy adjsutable trackbar with superflex joint
Stainless steel
brake lines
transfer case with sye hnt
steering column and wiring
steering box
cat convertor with 2 new 02 sensors
What do you want for the 30 aussie?
How much do you want for the tires?
the front springs, uca lca spoken for? I'd like the whole lift.
seansxj has dibs on the front axle and shocks
josh and i are using anything that is not listed up there.
PM'd you on the Steering box.. just for grins, what are you guys asking for the Trans Case? Thanks
P.S. Hey Jon, you gonna be sporting a non renix rig since Sean is taking the front axle?
pms sent!
rear axle is going to be first guy that shows up with cash.
pms sent
t case came off an auto.
a guy is coming too look at it tonight
alternator, starter, ps pump(needs a reservior, they are 16$ at napa),
15$ each
all work great
entire dash with guages and all
20
all 6 injectors with fuel rail
throttle body with all 3 sensors
air box
