Jeep Cherokee XJ Aftermarket Heavy Duty Front Driveshaft
1slowhatch
Knoxville, TN
Heavy duty aftermarket front drive shaft. I used it on my '91 Jeep Cherokee XJ 4.0 5 speed with the factory high pinion D30. These are close to $250 new. Obviously this one is used and will need 1 u joint, the slip joint is good, tubing is straight, double cardan joint feels fine. Extended length looks to be 31", collapsed is around 27". However, I did manage to damage the dust seal when collapsing the shaft. Shouldn't matter on a trail rig or just lube often.
I'm asking $100. Located in Knoxville, TN. Can ship inexpensively through my job.
