jcroffroad
www.jcroffroad.com
- Kalamazoo, mi
If you are traversing tight winding trails or tough rock climbs you are bound to (if you haven't already!?!) dent or gouge your Jeep XJ's rear upper quarter panels. Once these panels are damaged, it's nearly impossible to mend without a hefty repair bill. But now there's another option! JcrOffroad is proud to offer our Jeep Cherokee Rear upper Quarter panels. For a seamless look, these panels bolt on to the side of your Cherokee using 10 countersunk 5/16" bolts.
Cherokee Rear Upper 97 & up --> here
Cherokee Rear Upper 96 & down --> here
Tired of bashing up the back end of your Cherokee? Have you already dented your lower rear 1/4 panels? Or do you constantly worry about damaging them while on the trail? JcrOffroad is now offering rear XJ 1/4 panel armor.
Cherokee Rear Lower 97 & up, Flare and Cut.
Flare:
Cut:
Cherokee Rear Lower 96 & down ---> Here
and don't forget our Gas Tank and Transfer Case Skids...
Tcase ---> Here
Gas Tank ---> Here
Flare:
Cut:
Tcase ---> Here
Gas Tank ---> Here
