January 2013 ROTM submission thread!
XJLI
Long Island, NY
This year, we're bringing back THEMES! This month's theme is SNOW Only pictures of XJs/MJs in the snow will be eligible!
Must be an XJ/MJ based vehicle.
Submissions must be placed in the official ROTM submission thread.
Red letter names only.
First 5 submissions will be voted on.
Must include a total of 2 pictures. Pics must be hosted by the submitter, and sized properly for forum viewing.
NOTE: High resolution versions of the winning rig's pictures submitted must be provided. The original picture file MUST be provided upon winning ROTM, no re-sized or altered pictures will be allowed.
Pictures must be recently taken, maximum of 1 year old allowed.
No copyrighted photos will be allowed. Photo credits and compensation for their use will NOT be provided.
Winning rig must provide permission to use the pictures as sees fit. If you are not the owner/photographer of the picture, their permission must be available in writing (via PM ok). FAILURE TO TO DO SO WILL RESULT IN FORFEITURE OF ROTM TITLE!
Winning rigs will be ineligible for the remainder of the calendar year.
Winner will be featured on the front page of NAXJA\
GO!
I think I may be going to a one picture template (for the calendar, and when framing a shot I don't plan for having a second PIP box somewhere in it) so at least one, but not both must be snow-riffic.
I'll play.
Sister's first ride.
'89 Cherokee 4.0, lovely Peugeot.
HP30. 3.55. Ruff stuff "hello Kitty" diff cover
29 spline 8.25.
RE 3.5" coils/leaf packs, Rancho shocks
SYE
15x8 Rock crawlers wrapped in 33x12.5 Duratracs
Late model front end swap w/ dick cepek lights
Custom headliner and Pioneer Headunit
And it has been built for, and work done by, my 15 year old sister. woo woo:shocked:
I'll give it another go.
Snow photo...
Second snow photo...
Specs...
2001 Sport.
Engine 4.0L stock
Trans AW4 Stock with aftermarket cooler
Tcase 231 Stock
Rear axle D44 ARB 4:56 gears, large spline alloy shafts, Tera disk brakes
Front axle D30 ARB, 4:56 gears, WJ brakes and steering (in the process of installing)
Custom Mattbuilt rear bumper with tire carrier, AT aluminum gas can holder and a Trasharoo.
Rigid front bumper, Warn X9000i winch.
Suspension...
Rear Deaver leafs, HD shackle boxes, 1.5 inch TNT ubolt eliminators.
TNT Y-link front end with DPG coils, RE track bar (being replaced by custom as the steering is installed)
TNT frame stiffeners.
Tires 285-70-17 Goodyear Duratracs
Wheels Eagle 17 inch series 140s with 4.5 inch back spacing
Airflow snorkel
Viair 450c compressor installed behind the right rear quarter panel
ARB Fridge
Bushwacker flat fender flares
JCR (I think) sliders
Might be too early for.good snow pics for some folks...maybe change theme and use snow later?? :dunno:
Guess Ill try again.
-1996 Jeep Cherokee Sport
-4.0 H.O/AW4/231
-AA SYE, wide chain
-Front Axle
-HP Dana 30
-4.56 Motive gears
-JCR UTK 1-ton steering
-Rancho steering stabilizer mount
-Rough Country quick discos
- Solid Diff. Cover
Rear Axle
-XJ D44
-4.56 Motive Gears
-Aussie Locker
-Solid Diff. Cover
-Disk brake Conversion (ZJ D35 parts and Rubicon D44 parts)
Suspension
-Rough Country Long Arm kit
-6.5" RC coils
-4.5" RC leafs
-1.5" RC shackles
-RC braided brake lines
-RC 2.2 performance shocks
-HD Engineering Shackle Relocation Brackets (V2)
Tires/Wheels
-33x10.5x15 BFG KM2's
-Procomp black D window wheels
Armor
-Home brew custom front bumper
-C4x4 rear bumper
-JCR stage 3 sliders
-Rough Country tcase skid
-oil pan skid
-OverlandXJ rear corner guards
-Gas tank skid
Misc
-Custom rear driveshaft
-Smittybuilt XRC8 winch
-Cobra CB radio
-Motion Offroad CB antenna mount
-River Raider Hi-Lift mounts
-Hella 500's
-Safari Snorkle
-Rustys steering box brace
-M.O.R.E motor mounts
-Durango steering box
-Pontiac GTX hood vents
-Optima Red Top
-v8 ZJ front sway bar
-Kenwood cd player
-Mossy Oak headliner
-99+ Door seals
-99+ Side Mirrors
-ZJ leather seats
-Rear side storage lock box
well I wasn't going to, since I'm currently on jack stands in the garage, so I'll post the specs when the pictures were taken. But, since nobody else seems to have snow photos.
Two weeks ago
Last January
HP Dana 44, ARB, 5.13 gears, homemade truss
Crossover steering and trackbar w/ heims, homemade trackbar braket
Rock Krawler 3 link w/ Ballistic Fab heims, 4.5" lift coils, ACOS adjustable spacers
Ford 9", Detroit, 5.13 gears, disk brakes
5.5" lift springs, 1" lift TNT boomerang shackles
36x13.5 IROKS, 16x10 steel beadlocks
Rancho 9000 shocks, limit straps
SYE, heavy duty driveshafts from Adams Driveshaft
HD Offroad frame stiffeners
Homemade high clearance trans crossmember w/ poly mount
Brown Dog poly engine mounts
JCR Offroad front winch bumper, 9000 lb Superwinch
JCR Offroad tire carrier rear bumper
Homemade steal taillight boxes
Rock slider welded in place of rocker panels
On board air (converted A/C) w/ 5 gallon tank
Dual Batteries w/ disconnect switches
800W (1600W peak) power inverter
CB, 2 Meter
Removable front doors w/ CJ hinges.
Homemade dash center panel, push button start
Homemade overhead speaker bar w/ dome light
Homemade dents, custom scratch-finished rattle can paint job
Specs:
1991 SWB MJ Eliminator, bucket seats & slider window
4.0L engine custom bored by xbadleej w/ cold sock intake
AX15 manual trans
NP231 from a late XJ
97+ mirrors and header panel (half hearted 97+ swap, the originals broke so I bolted on newer parts...)
29 spline 8.25, 3.55s, ZJ discs, SUA
dana 30, 3.55s, aussie, ruffstuff cover, V8 ZJ tie rod
4" lift (approx)
custom heavy duty trans crossmember I built out of leftover box tube/plate/pipe from other projects
stupid smashed up exhaust and cherry bomb
2x6 steel tube bumpers front and rear w/ recovery points
33" BFG ATs on beat up rims
wheeled frequently, tail lights held in with speed tape
This morning, parked in my driveway. There's a reason I only own Jeeps :rof:
NACFest 2012
