Is this Carrier still good?
ChuckD
Kerman, CA
This is a result from my first atempt at setting up my R&P in my D44. The guy who helped me grounded down the edge of the carrier to get the bearing puller to work. Well before I atempt this again, I just want to be sure that this won't effect my setup or maybe cause noise later.
The second atempt will have a new R&P set and a new installation kit. If this carrier is no good, I stil have the old carrier. Then I would have to use the thick gears. Anyone know where I can get the thick ones at a reasonable price for 4.10 ratio?
Yes, that's fine.
Make sure there are no raised edges where the grinding occured when you seat the shims and bearing back on.
CRASH
