Rough 01
- Herndon, VA
The time is finally here. I'm going to do a major lift to my Jeep in a couple of months and I would like some advice.
I'm looking to use the vehicle as a dd and it will only see about 40% off road action. I want something with spring rates similar to the up-country springs I'm currently running. I also want to stay with 31" tires (probably BFG MT) on my stock rims. I want to have a lot of travel so that I can do forest trails and mild rocks at a good rate of speed. I don't have a lot of rocks to crawl on and there isn't a lot of mud close by. What I do have is a lot of small rocks that really vibrate the hell out of the XJ and its occupants. I want to have enough travel to take these obsticals at a good speed and not ruin my components right off the bat.
I currently have a '98 Sport with an auto with the NP231 transfer case and the 8.25 rear axle with stock gears front and rear.
I'm thinking about getting the RE 4.5" Superflex kit with the RE SYE and CV driveshaft. I want to swap out the fixed length Upper and lower control arms for the adjustables. I also want to swap out the quick disconnects for the JKS Gen II. I want to run the Bilstein 5150 shocks but I haven't heard any reviews on how long they hold up and how they ride.
I am also planning on regearing to 4.56 as well as adding a no-slip to the rear. I want to go with 4.56 since it will give me a little more torque than stock (I don't really care about gas mileage) and I may want to go to 33" when I stop using it for a dd.
Some questions I don't have answered. Will I need a new front driveshaft for this lift? If not, how high can I go with the stock front driveshaft? Will I need shims for the rear springs and transfer case drop even with the CV driveshaft and SYE? I really don't want to lower the transfer case since I'm paying a lot of money to get it away from the ground.
Thanks for all you help and I may see you on the trail!
Rough
Rough
