jforse
- Duluth, Minnesota
I've had a few requests for pics on the Iron Rock long arm kit. Here are the only ones I have and they are from the install. I need to get a new camera and flex it out for you guys. I origanally had a RE SuperFlex 4.5" kit. So I basically just replaced the RE short arms with the Iron Rock Long arm kit. This is the easiest long arm kit I have ever installed. (RE, RK, TNT) It is a complete bolt in. No cutting and no welding required. In the pics you can see the lower control arm brackets can be left intact in case you want to return the vehicle back to short arms. I will be trimming this bracket. I will also be adding a set of TNT frame stiffeners and then I will be welding the IR brackets to the stiffeners. It is not necessary but I feel it is the best option for my set-up. This thing rides like a champ with the Long arms installed. Even with the crappy DT shocks. If you have any questions feel free to ask.
