Ok question here. What is a clock jig, and why should it be done to a T-case? Feel free to ridicule and laugh but an honest answer in the process please.
Its a jig that you bolt on to the tranny using the holes that the tcase studs go through. The jig has holes in it so you can drill new holes for the tcase studs to go through. What this does is rotate the tcase up so that it doesn't hang below the unibody rails.
More or less what he said. The whole idea is that your t case isn't hanging as low as before. A lot of people do it so they can run a flat belly pan. Wether it "should" be done our not is entirely up to you and what your goals are. You'll probably be fine without it, but it's one of those things that's just so easy you might as well.
well if you're nearby bigkin you can just pay him? I believe he mentioned he already had it in a flat rate box. we'll talk after this weekend let me know if you end up using it
