Hi,
I have a 2000 XJ with the federal emissions package (2 O2 sensors).
Sometimes, but now always, when idling at a stop light, I will get a very rough idle, where I need to keep my foot on the gas to keep it from stalling.
When I give it gas during the fits of rough idle, there is a very, very sluggish throttle response, and it will surge/pulse.
Also, in general, when idling RPM's fluctuate slightly, maybe 50-60 rpm. The Jeep will idle fine all day, and randomly start acting up.
Here's what I've done to try to diagnose it so far:
Looking at my scanner when running, I'm not seeing any weird MAP values, so I'm assuming my MAP sensor is good. I don't know how to test the coil rail.
I don't think it's a vapor lock issue, since I don't have a problem restarting the jeep after shutting it off, and I don't have any pre-cats with the federal emissions package. Also, this idling issue can happen with the hood completely open.
The only codes I have is for a bad downstream O2 sensor and missing battery temp sensor. I don't believe either of those have anything to do with how the engine runs.
Fuel Trims:
Does anyone have any idea?
- NEW IAC
- New Mopar TPS
- New NTK Upstream O2 sensor
- Cleaned throttle body
- New NTK copper plugs
- New TUPY cylinder head (had this problem before and after the new cylinder head)
- Smoke tested for Vacuum leaks - no leaks
- Fuel Pressure Test - Fuel pressure tested good during bad idle
- New Coil Rail
- Multi-meter tested all grounds, battery terminals are new, soldered on copper lugs on cables.
Fuel Trims:
- I did notice that I have some rich fuel trims during these fits. I'll attach a picture of these
- LTFT- 33.59
- STFT- -27.34
- Due to the fuel trims, I'm thinking one or more of my injectors are intermittently getting stuck open, however; I'm not sure how to test that.
