hey guys,
here are snap shots of my log files using my innovate 02 OBDII scanner
please tell me what do you technically think of the trend. I have some interesting observations
light green is MAP, red is spark advance BTDC, violet is RPM, etcc
the 1st log was recorded while i was gunning it full throttle through a 1-2-3 shift
- why is my throttle position sensor not reading more than 74% at WOT??
- my MAP sensor as well wont reach the 14.7 psi atmospheric even at WOT. I know that MAP reading at WOT should nearly match atmospheric.
- spark advance is a little bit retarded maybe? ranging from 15 to 22 degrees BTDC, it stays at around 10BTDC at idle and jumps to 35 BTDC sometimes during mid throttle.
- calculating my gauge vacum reading at idle from the MAP reading I have around 17.8 in-HG at 14.6psi atmospheric. is that healthy enough?
-Intake air temp is ranges from 120F to 160F
-short and long term fuel trims are very stable.
- The jeep generally running very well now after I installed the famous bosch 4 hole 22lb/hr injectors. smooth idle and reduced pinging and improved throttle response
and my XJ is a 2001 4.0 with an NV3550 and a 3.55 rear DANA35C. ( export version) .I cant get my 0-62mph time under 8.5 sec with 255/60R15 tyres.
and I have all the performance bolt ons I can think of, complete exhaust system with tube headers, intake, 62mm throttle body, etc, etc.., I am even running 92 octane currently .
shouldn't I be at least 1 sec quicker with that higher, rear axle ratio?
[/IMG]
[/IMG]
