SeanP
- Rocklin, CA
Well, I guess this is modified stuff...
I have done extensive welding on my rig over that last many moons. Most with my battery disconnected, but not all. I did have the PCM disconnected for a bunch and put the connectors back on. My power distribution unit (relay box) was moved a little but the wiring wasn't disconnected. My ARB and rock lights are unplugged.
OK here's the symptoms:
Windshield washers started even though the stalk was in the off position. I could increase the speed of them but they just ended up stopping with the switch in the off position mid-stroke. Weird.
Drove the rig, but it wouldn't shift from 1 to 2. (new crawler box and gears are SLOOOOW
Headlights wont work. The panel lights work but the two arrows for the hazard/turnsignals are on solidly. When I use the turn signal, the light that illuminates the shifter blinks.
AC works, but it's not turning on the e-fan like it should.
That's just the stuff I tried, there might be more fun stuff yet to be discovered.
I disconnected the battery and reconnected it. Mind you the rig has been started twice in the last year. It's a 97. WTF is up? Did I fry the PCM? Weird, weird, weird.
SeanP
SeanP
