cds36
- San Bernardino Ca
Well after having my rubicon tie rod I thought id change it up a little bit so decided to try the Zj steering. The kit Thanks to GERR has everything you need for the bolt on steering.
Draglink, Tierod, Tierod ends.
This is my rubicon tierod setup ....
After taking out the RE tierod I noticed right away that the tierod ends on the Zj were alot beefier than th RE. The tierod themselves were pretty much the same size. I know the RE is chromoly Im not sure if the zj is but iknow its solid compared to the stock hollow.
RE top, Zj bottom
Pretty damm beefy
The install took maybe 1 hour if that. While I was down there I tightened up all my suspension.
Well after driving it it feels pretty damm good I must say, A definate step up tierod end wise from the RE Tierod ends. It need to be aligned to get the total feel of it. I will post the results after the alignment. If you are interested in getting the kit contact GERR whole sells the kit. Great guy and Fast Service you wont go wrong
RE top, Zj bottom
Pretty damm beefy
