Installed JCR front bumper tie in brackets
Unbolting the steering box can cause it ;)
what you need to do now is unlock the steering wheel and rotate the adjustment sleeve on the drag link to re-center the wheel.
incorrect toe in/out is adjusted by loosening the tie rod adjustment sleeve
Yup, two different sleeves
Though if you get an alignment they should adjust both
Simply unbolting and rebolting the steering box should not change the alignment. Was a new spacer part of the kit? If so, simply adjust the drag link sleeve. All that changes is steering wheel center and does not affect toe.
Center steering wheel with draglink sleeve, then use tape measure to set toe in/out with tierod sleeve.
You want the front of the tire to be 1/8-1/4" in from the rear of front tire measurement, so If back of tire measure 58", front should be 57 3/4 to 7/8".
No need to spend 80 bucks to adjust one thing and center a wheel ;)
Still may need minor centering of steering well after toe adjustment.
What section of the tire do you measure from?
