So the specs match, but the flow rate is more? What kind of logic is that?Yes the specs for the 703 and 784 injectors match the Jeep's OEM injectors, infact flow rate is a little bit better/higher and they have a four hole spray "nozzle"
Don't care about ben. Ben is wrong.Info from ben824^
So then.... its a waste to swap injectors?
I keep hearing about people swapping injectors and trying to figure out the facts...
www.precisionautoinjectors.com has the correct and later model injectors as do other vendors. Takes the guesswork out of it.
I've been running their 96-98 4.0 injectors for 5 months now without any problems.![]()
