tonofclay2
- Clovis, CA
Does anyone know what these look like when the rear quarter panel is folded in for better exit clearance?
The same as when the rear quarter isn't folded, only more visible.
These are designed to sit directly on the "frame" and lower your hitch 1/4".
Yeah that makes more sense, thanks.
That is something I thought about as well, might just be the next thing on the list.
Originally Posted by garr
Really nice Stuff, Now that you have the shackel (rear) end covered is it possible to make a bolt on extension for the front leaf spring mount?
So we can gain a little lift & keep the pinion angle correct without having to shim?
Front & rear leaf spring extensions would be great!!
Any word on the Fronts? I am hoping that they will be available soon.
I also think the front and rear would be awesome, some 3.5 RE leaves, but end up with an awesome ride at around 4.5 to 5!
Is there any way to improve the shackle angle without adding any lift to the rear? I recently put on an RE 4.5" kit and it is already super tall, but the shackles are perfectly vertical and I'd like to fix that. I don't need to add any lift though. Is there a way to make this bracket with a nutsert or something that could go into the stock pocket and keep the same height of the body-side shackle bolt, but move it forward a few inches.
I may be wrong, but an RE 4.5 kit is a 3 inch leaf pack and a shackle for the rear..? In that case you could just throw your stock length shackles back on..
I got mine in 4 days.whats the turn around time for these right now?
