- Columbus, In
Are these available for purchase yet?
PM sent.
Sorry should have been more specific... I meant use the nutstrip still, but instead of trying to thread up into them, run them thru the nutstrip and then thru the "frame" and then put everything into place and secure with nuts.Thanks for the help
I have a 97 XJ. The bolts don't line up and there is a 4th bolt for the bumper that is in the way. Has anyone installed these on a 97 or newer XJ.
Any force great anough to bend the unibody with .25" 2X4 installed would trash the unibody worse with thinner material in the rails for the bumper mounts. 3/16" would work but I wouldn't go thinner than that.I wonder why everyone seems to think 0.25 2x4 is necessary for sleeving the rear unitbody to make bumper mounts. It seems to me that you would use thinner 2x4 steel because as others have said the unitbody would bend before the 2x4 steel well dont you want it the other way around dont you want the 2x4 to bend before the unitbody? why not use 3/16 instead of 0.25 or even 1/8 u can replace the 2x4 but not the unitbody plus it would be easier to get the nut strip in and all while not losing that much strength. Just seems silly to do all that then hit some thing and tear up the unitbody. anybody feeling me on this?
Would like to know this as well as I want these....bad
Come and get your pair and we can install them at my place, so I can get a look for myself. I have only had one person with a 97 and up jeep write me to tell me they have a fitment issue.
I'm going to put mine in this weekend. I have a 3" lift with new springs and factory shackles. What's the right shackle angle? Tilted which way?
45 \ point it to the FRONT OF THE JEEP..
That and they live like 20 minutes from each other!now if that isnt good customer service, i dont know what is
That and they live like 20 minutes from each other!![]()
A couple of pictures of the flex created with the use of Brian's shackle relocation brackets.
Good stuff!
