Important
You caved in and gave him the job back did you. We all know you're a big softie. And I'll probably but it ended with a big hug and singing Kumbaya.
Never done one before but how bad are head gaskets to replace on a 4.0? Thinking of picking up an 01 from a friend but says needs a head gasket.
Sent from my XT1565 using Tapatalk
this
but since it's an 01 I'm gonna go with the head is cracked between 3 and 4.
so I'd factor a new head into that purchase price.
I can just swap the 01 head out with one from like a 98-99 correct? Aren't those the better heads?
So it needs to be another 00-01 head? Sorry never messed with swapping heads out.
the castings were revised to add material.
TUPY marked heads. As long as the reman is a TUPY head it's good.
You can swap an earlier head, but you either have to make something to hold the coil rail, or swap to a viper coil and a wire set.
http://naxja.org/forum/showpost.php?p=245464239&postcount=12
If you've got a good head laying around the viper coil isn't that expensive. Slap it on the fender and go. That's my eventual plan.
I always found sand bar drinking to be completely natural.
Only state in the union (pretty sure) where a first DUI is just a traffic ticket.
We like our alcohol, doesn't hurt that it's so accessable...
Sent from my A1-840 using Tapatalk
Also, pretty sure my 4.0's days are numbered, clatters like a SOB except when fully warm. 310k ish miles, all original. On the lookout for a replacement, hoping I can score one so I don't have to pull one at a JY.
