Most of the public safety in our area are on a digital band trunk system.
Our system is on an encrypted chip...even scanner land can't listen.
A few years ago the FCC made all public service move off the 800 band to 700...we've moved since then and I'm not even sure we are still in the 700. I would doubt these radios could transmit on a public safety channel.
mac 'but I've been wrong before' gyvr
https://www.radioreference.com/apps/db/?ctid=694
encrypted P25.
Still in the 85x mhz range according to the database, last updated about a year ago.
P25 encryption has been broken, it has a flawed implementation, and it was only 40bit RC4 to begin with (assuming moto radios). Anyone can listen if they've got half a brain, can solder a discriminator into a radio and compile some code.
If my county were doing P25 I'd be breaking it, but we didn't get on that bandwagon, and now the state is funding the move to NXDN.
NXDN encryption is for serious. AES based and likely in the 128-156 bit range.
Currently no one has broken it with a shortcut, and it would take a consumer level PC decades to run through the possible key set. You might shorten that to a year if you cluster computed it with a basement full of i7's.
With the exception of law enforcement all of my county/city agencies are regular FM VHF, and this radio is fully capable of transmitting and receiving. The sheriff maintains a regular VHF channel as well for inter agency communications. I've not heard anything on it though.
I have picked up the fire/EMS radios, and the municipal departments.
The potential exists for interference though, so while you can't listen to a trunked system with it, you could still interfere if you broadcasted on their frequencies.
Don't be dumb and transmit in realms you're not licensed for.
