Important
and your three can tell all the ones I've pulled and had that they should be broken.
You know, since I've now owned 4 renix jeeps. I guess that one you had problems with gives you all the information you need to call it shitty.
there's nothing wrong with the system.
you can hate it all you want because you couldn't make it work, but I've fixed a bunch of them that had issues cheaply and effectively. None of them involved replacing the ECU.
and since you're apparently such a fan of the HO system, what about all those bad PCMs that chrysler put out? The ones with pins that crack from the PCB? Did the french engineer those too?
I thought my nacho machine was broke one time. I realized it was not plugged in.
Cheese "yummy nachos FTW!" Man
Hey guys.
Who's the resident Dana 60 expert these days? My front hub on the driver's side is toast and I cant get the nut off the spindle to remove the hub assy.
I'll post pics later in a different thread but figured I'd ask my long lost buddy's!
Can't say I've ever replaced an HO. And if I did, it probably wouldn't take 3 to find one that works.
Tell me, if renix was so great... Why did Chrysler drop it?
Hey guys.
I've split the nut and beat them off when the spindle is trashed
