Oh gotcha. Shredding R&P's does not sound fun.It's a 4runner with body removed behind the body so pretty light. 40s are common but it shreds r&p if they aren't set up deep like a drag setup.
since my electrician is MIA I have a question that I'm sure many here would know the answer too...
My panel is in my garage. It has a 220 plug coming out of it but it has a male end on it. The homes' PO used it to back feed his generator into the panel. The breaker is turned off. Is there a way to change the end out to a male end and use that to plug in a welder/compressor/plasma? Is it as simple as just changing the plug and flicking the breaker on?
yessince my electrician is MIA I have a question that I'm sure many here would know the answer too...
Grand daughter just born! Mom and baby both healthy.![]()
What size breaker is it connected to?
this.
and I'd not just stick an end on it. Surface mount a box to the wall and put an outlet in.
Thats all mine is. A surface mounted box right below my panel.
What's the question (s)?
I'm going to bed for a couple hours but then up at 6 for a traffic detail...
mac 'least we can tell you to do a search' gyvr
About lifting it a couple inches. It's a 10yr old truck so I'd assume there is a tried and true method out there.
Not that's it's a biggie. I'll get around to searching eventually. I just found it funny that I got no responses.
That happen to me a while back on jeep forum. Made a build thread, got viewed a bunch and not a signal comment. That's why I give naxja the money.
J I was drinking pappy, it was yummy.
