HaleYes
- Clay County, IL
Haleyes said:please splain.![]()
IllianaXJ said:That's about what my fuel gauge looks like all the time. I can only afford $20 or so at a time, so my tank almost never makes it over 1/2.
RedHeep said:If you filled it all the way up one time, then you could put $20 in at a time and it would never get below 1/2![]()
what Travis said basically........ really not sure how else to splain itHaleyes said:please splain.![]()
Roxtar said:Hey all, I'm looking for an alum fairlead.
Yea, I know, check the classifieds. I did.
Since this is the kind of item that often just gets put on a shelf rather than sold I figured I'd ask if anyone had one they could sell.
meh, I call BS on the whole it will burn up your pump because it's not getting cooled.bshaw said:what Travis said basically........ really not sure how else to splain it![]()
I never thought of the return fuel being hot from the motor.sgtmack said:The low fuel isn't much of an issue in the winter, but in warm temps we've seen fuel temps over 180 deg with a low fuel level. It gets warmed by engine heat as it goes through the fuel rail then returned to the tank. The three best driveablility techs i've worked with all agree it is the second leading cause of early failure, after plugged filters.
Neal
lasted i checked the fuel pump does not stop pumping because of low fuel or no fuel..... motor continues to run with nothing going through it..... think of it like a boat motor i guess, with no water. common sense would tell me it's going to fry.... either way I'm not going to be convinced otherwise nor are you. done.87manche said:I think that the much more likely scenario with the tank that low is that it will simply starve the pump, and when it sucks are the motor is going to overspeed and then eat itself up, but not because it over heated.
yeah, you just agreed with me. The pump won't stop, but when it runs out of fluid it's still going to keep on going, so the motor will overspeed.bshaw said:lasted i checked the fuel pump does not stop pumping because of low fuel or no fuel..... motor continues to run with nothing going through it..... think of it like a boat motor i guess, with no water. common sense would tell me it's going to fry.... either way I'm not going to be convinced otherwise nor are you. done.
now go have a good b-day! asshat!![]()
