XJ&CHZ4ME
- Unionville, MO
At least you let me go first.
like using a step bit...
You can return the favor this weekend![]()
I'm guessing I won't have to since there are other folks that are more your type going to be there.
Is there an adjustment for the tension?Well snapped the belt on the lawn mower last week and have been trying to find a replacement for it. It's a ½"x99"long belt. All the stores either have the 98" long one or the 100" long belt. Does anybody think it would hurt it at all to go with a belt that's either an inch smaller or an inch bigger? Just trying options before I have to order online.
Ran all new plumbing to the laundry room in the house on Saturday/Sunday. spent a lot of time getting to know the crawl space. had a couple chats with Fred the big black spider who just sat in his corner all day and watched me work. after everything was done i figured id take a little break from working and relax. after about 3 hours i got back up to put the washer and drier in the room.... hooked everything up, guess what, no power in any of the outlets. ohh the joys of a new home.
Fire your home inspector...
mac 'hope it wasn't seanR' gyvr
BWHAHAHAHAHAHA!the sooner i get these little honey do type projects done the sooner i can get started on the fun one, the bar.
We had no power to one leg on the dryer plug in when we bought this house. The dryer would spin and the timer would work, but no heat. I tested the outlet a couple times and had voltage. So I spent a pissload of money swapping parts onto the dryer figuring my BILs and buddies who helped move everything damaged something in the process. Still nothing. So I broke down and bought a new dryer. Got it installed... Spins and the timer runs..no heat. Checked it one more time, yup voltage... Realized I always checked the same leg not both of them and a dryer uses two 110v legs not a true 220v. Went do to the circuit breakers and the wire for the second leg is tucked in the back of the panel. Attached it and bingo the dryer worked.Ran all new plumbing to the laundry room in the house on Saturday/Sunday. spent a lot of time getting to know the crawl space. had a couple chats with Fred the big black spider who just sat in his corner all day and watched me work. after everything was done i figured id take a little break from working and relax. after about 3 hours i got back up to put the washer and drier in the room.... hooked everything up, guess what, no power in any of the outlets. ohh the joys of a new home.
