- Warsaw, IN
Thats what i thought. Im thinking it just means how much porcelain is sticking out past the metal part of the plug.
Exactly right.
I've... Had one... Since I started driving.
It's a Va jeep. No debilitating rust to speak of.
Think swapping the leafs and springs from side to side May help?
If they stick out too far the could possible touch a piston. Which is bad.
The length it sticks out is also related to the heat range of the plug but I can't remember exactly how.
It's the 5.2. But still...4.0's run the best on the cheapest plugs you can find. You're having heartache over 12 bucks worth of sparkplugs.
I think it has to do with engine torque. Just a constant on and off making the body roll a little more that direction.
Swapping sides will probably help.
My 4.0s have always ran best on Champion copper truck plugs.
Lol I see what you did there and that would have been hilarious.
Polar 'Easton is full of the police this week' Jeep
I did notice increased body roll under torque in that direction when I removed my sway bar... Which was also when I installed a geared axle. And that's when it started to pronounce itself.
For you Flex..
:cheers:
Big Hank
