Prepmech
NAXJA Member #981
- Neoga/Decatur, IL
goodburbon said:Overall that thing is a way better design (at least on the front end) than the xj. Dual piston calipers, Boxed control arms, crossover steering, large diameter tie rod, anti sway bar is further away from the spring as is the shock mount. Only downside is that front Low pinion axle and WTF is that front driveshaft? CV joints full of fluid at both ends flanged to the T-case and Pinoin?
Take a look at how the front lower control arms mount to the front axle, then go look at an XJ.
The WJ's lower control arms mount farther inboard than an XJ's, it causes some serious death-wobble when you lift them. Teraflex won't even sell stock replacement lower control arms anymore, you have to get the wider ones with new axle brackets.
