- NE Indiana
I'm on vacation...
mac 'no one is paying me to be on
' gyvr
Canceled my Amazon prime account. Tired of paying for 2 day shipping and it takes 3.
apprentice for what
the dark side.
why rent big johnsons when you can get them for free? :twak:I gave up and rented one of those big Johnson's. Finished it in less than an hour.
Now to clean up the edges and seal it.
Yeah, that's an FMVSS requirement. There are two separate blinker cans on 96- as a result. 97+ it's an electronic module that gets stuck up under the dash right near the headlight switch.The hazzards and blinkers are on different circuits, if I remember correctly. It's a safety thing, like being able to run your flashers w/o the key on.
I forget the differences between LA, A, and Magnum blocks, but Magnum 5.9s are everywhere up here and I will help you with wiring if you don't mind staying EFI. It is not that hard.Ha yeah... I can never seem to find one in a junk pile around here. I just want a mopar 360 i can slap a carb on. Simple jobbie.
Finding the xj to put it in at my price point will be more difficult
XJs actually never, ever got CAN bus, despite what Novak and others say. All 91+ XJs have a CCD bus. All 97+ ones put a lot more stuff on it, including the instrument panel.yeah, but in XJ land they didn't go full CAN BUS until 97.
probably because they developed it all for the ZJ in 96 it looks like.
I assume 96+ ZJ has gauges driven by PCM and the like.
I'm zj tarded, just know what to take from those that works. if the RKE module is the same in the ZJs and WJs that would be a god source for us, because al of hte grands had keyless entry. Programming fobs brings the suck though.
I discovered mine blows a monster cloud of oil smoke if I let it idle for a while and then launch it yesterday. It's been disposing of oil rather quickly even after I replaced all the seals and gaskets, so pretty sure the rings or valve seals are shot.I've been doing for about 4 years now. She's getting tired but it's so reliable and doesn't burn or leak a drop of oil.
One of these days I'll get the balls to swap it out.
WTF, what pistons are those? I could swear I found a much cheaper option.Mine is like 20 psi at 55. Typical Renix.
I'll build a stroker eventually. Pistons are 500 bucks so it'll take a while.
Google CH3110104 next time you need one cheap. Rockauto has em for $11.
Waiting for a Jeep part?Due to my "rural" location items get turned over to the local post office for delivery.
Icon ic944. For use with 4.0 length rods.
I'm on vacation...
mac 'no one is paying me to be on' gyvr
should have said something. we could have drove up there and got dinnerYou are on vacation and I am in Fort Wayne, haha. Cork n cleave in a few thanks for the tip!
Also, just sayin', a mantrans bellhousing from a 3.9L V6 Dakota will bolt a 5.2 or 5.9 to an AX15 or NV3550I wouldn't recommend putting a 5.9 in front of one but a 5.2, sure.
(if you go this route, just grab the whole dakota transmission. It's literally the same as an XJ one except the shift tower and lever and the bellhousing.)
