- Southwest IN
Moving back to NJ in May. Its been real. Please check out my FOR SALE posting.
Nooooo!
should be 4 nuts (13mm, iirc) holding the transmission mount to the crossmember. Pull those.
Then you're looking at the two 18mm bolts holding the transmission mount to the transmission (not the transfer case.) Pull those, make sure you have the transmission supported.
Now you should be able to see the last 9/16" nut holding the last stud on the transfer case. They hid it in there for some horrible reason on the autos.
there are 4 nuts up in there (giggity)
Kinda like that time we shared the top bunk in Travis' RV...
Pretty much, yeah![]()
Nope. Look up at the crossmember directly below the trans mount. You should see 4 holes in a square pattern, there are 4 nuts up in there (giggity) that need removed.
you're fixing it not chopping it up, right? :shiver:
awesome. If you were going to chop it up I had half a mind to buy it off you at WF and try to drive it home :wierd:many many plans...chopping it up is not in the plan. first step is to get the 4.2 running again. stupid computer controlled carbs are making me feel stupid. once its running its getting a full strip and repaint, bedliner and a new interior. then if money allows in a year or so, the motor will be swapped for a 4cyl cummins.
i plan on owning this forever
for the cut or to hold his noggin together?
http://youtu.be/RbHdsJ_Sw7s
http://youtu.be/qqrVmP5vOeQ
might be a couple jeeps you recognize...
from rocks and valley's 9/1/11
mac 'it was warm' gyvr
