My new to me 99 was great from Madison to my parents. Pulled out of their drive and heard grinding when applying the brakes. I took it easy and figured a pad had separated. Well I pulled the drivers side apart Saturday and found the p.o had used washers behind the rotors instead of using the proper cast 99 rotors. So I bought two new rotors today. After work I completed the driver side no problem. The passenger side is a bit difficult as the p.o snapped a stud off and put a bolt and nut through the wheel to hide it, also did the washers behind the rotor and put only the upper caliper bolt in due to the hole being drilled out and wallowed out on the knuckle so the threads never grabbed, the bottom bolt was not even threaded in at all for the caliper. Thank God I made it home alive with no problems. I'm pissed at myself for not catching it when I bought it. It never made any noise or anything and did not pull at all. :flamemad:
Anyone have a Dana 30 passenger steering knuckle for sale?
